 Post subject: Can't copy into nexstart menu
PostPosted: Thu Nov 10, 2011 1:14 pm
So i wanted to use a nexstart menu as a drop and distribute bin but can't seem to work.
http://imageshack.us/photo/my-images/689/uploadwe.jpg/
(couldn't get the image to work ??? so kindly visit the page)
as described in the image i want to be abled to both copy or move items in the menu or from the menu....
P.s I deattach the menu and toggle "always on top" and use it everywhere if you are wondering. I do not have "requires crtl or shift when copying" on.
 Post subject: Re: Can't copy into nexstart menu
PostPosted: Thu Nov 10, 2011 10:45 pm
Just to confirm, what is the source of that shortcut in the image (i.e.; where are you dragging it from)? The Windows Desktop?
PostPosted: Fri Nov 11, 2011 8:15 am
Yes I'm dragging it from the desktop into the menu (which is a drive) where i want it to be copied not moved.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 245 guests
