Do you find the Tip of the Day pop ups useful?
Yes, it already taught me something I didn't know.
43%
[ 3 ]
Yes, but so far I haven't learned anything from it.
0%
[ 0 ]
What's a Tip of the Day?
0%
[ 0 ]
No, but I have that option enabled anyway.
0%
[ 0 ]
No. I think the Tip of the Day pop up is annoying and turned it off.
57%
[ 4 ]
Total votes : 7
 Post subject: Tip of the Day
PostPosted: Tue Apr 25, 2006 8:17 am
Quick poll regarding the Tip of the Day:
PostPosted: Tue Apr 25, 2006 8:31 am
I'd just like to say that I did turn it off but should have probably left it on :) I am sure there is a lot of stuff I still need to know.
http://www.scarebear.org/
PostPosted: Tue Apr 25, 2006 8:36 am
Hey looking at your theme with the new NS version right now. Just noticed there is a problem with the Quick Launch buttons and mouse overs, going to check now if it's a bug in NS or a problem with the theme.
PostPosted: Tue Apr 25, 2006 8:43 am
Ok, figured it out. You told it to use MouseOver and Push In versions of the Quick Launch button, but you only provided the normal bitmap. Just a question of turning those options off, but still, NS should have automatically used the normal version for the other two states.
PostPosted: Tue Apr 25, 2006 9:18 am
Good thing I build incomplete/dodgy themes! :wink:
I'll fix that up and the incorrect arrow icons I noticed after zipping it up...
PostPosted: Tue Apr 25, 2006 9:29 am
And I fixed it already in NextSTART too. I also noted that the 3D frame around the icons in WorkShelf starts at the wrong place and fixed that already too.
Love the theme - but Holly is going to cry foul again due to the size of the desktop modules, hehe.
Ah, change the maximum text percentage to 80%, otherwise long shelf titles WILL run off the right tab edge.
Users browsing this forum: No registered users and 188 guests
