 Post subject: workshelf and nextstart themes
PostPosted: Sat Apr 24, 2004 1:26 pm
do the next start themes also work with the workshelf proggy ?
and visa versa ?
why has nobody decided to winzip 5-10 themes in one so we dont have to download each one individually, they look good with the thumb pics but the best result is when you have downloaded them and run them to see what happens. :wink:
 Profile ICQ
PostPosted: Sat Apr 24, 2004 7:35 pm
NextSTART and WorkShelf themes are two different things, however, by unspoken convention, a NextSTART theme usually has a WorkShelf companion (and vice-versa, depends on the way you look at it). The exception is, of course, those old NextSTART 2.x themes made before WorkShelf was first released.
Themes are very individual things, what might appeal to some does not appeal to others. So why force people to waste bandwidth downloading a theme pak from which they might only use a couple of themes?
With individual themes you can download only the themes you like. Also, I'm not sure if you are aware of this but you can download a bunch of themes, in one go - into the \winstep\autoinstall\ folder - and then make NextSTART install them all at once (info on how to do this is in the User Guide :) ).
Users browsing this forum: ppetroff60 and 167 guests
