 Post subject: Can I add an Icon to the tray to minimize all open windows?
PostPosted: Tue Feb 14, 2012 2:39 pm
I often find myself with 5-10 open windows at once, and then want to minimize them all at once. Say when a co-worker walks up and I need to open one thing for them without having everything I was working remain visible as I move to some application, etc.
With the WinXP taskbar, there is a button that takes you straight to the desktop by minimizing all open windows. Is there a way to add that button to the Nexus toolbar?
Thanks,
Jay
 Post subject: Re: Can I add an Icon to the tray to minimize all open windo
PostPosted: Tue Feb 14, 2012 2:58 pm
Found it...
I was able to make the XP TaskBar visible and then drag and drop the "Desktop Icon" directly onto the Nexus tool bar.
Jay
PostPosted: Tue Feb 14, 2012 8:18 pm
You should also try looking at Nexus/Xtreme 'internal commands'. Lots of little useful commands for things like that.
Users browsing this forum: Bing [Bot] and 147 guests
