 Post subject: Start menu and Winstep
PostPosted: Fri Mar 30, 2012 10:48 pm
This seems to be happening when Nexus is running, the shutdown options popup on the start-menu is faded. Any ideas? When Nexus is uninstalled, this problem disappears. Thanks.
Am running Winstep Xtreme 12.2 on windows 7 home premium 32bit.
 Post subject: Re: Start menu and Winstep
PostPosted: Sat Mar 31, 2012 2:47 am
Never heard of this, sorry.
At first I thought it might be a problem with the Start Menu IC in the Nexus dock, but I just tried it here on Windows 7 x64 and I had no problems seeing the Shutdown popup menu.
Has anyone else seen this?
Also, what happens if you reboot your system and then use the Start Menu button in the taskbar instead of the Start Menu icon on Nexus?
PostPosted: Sat Mar 31, 2012 4:35 am
The same...I tried uninstalling and re-installing, yet end up with the same result.
PostPosted: Sat Mar 31, 2012 10:36 pm
UPDATE: after toying around with this I found the problem was stardock's windowfx 5 causing this to happen. I disabled it to find my start menu back to normal. Wasn't winstep at all. Will be making stardock aware of this. :D
Users browsing this forum: No registered users and 234 guests
