 Post subject: Request for a Theme
PostPosted: Mon Apr 02, 2012 5:12 pm
hey guys,
i'm looking for a completely black theme for winstep xtreme but i couldn't find it.
i want to have a matching theme to fit my black aero desktop:
could someone create something like this?
thx in advance,
Tom
 Post subject: Re: Request for a Theme
PostPosted: Mon Apr 02, 2012 8:23 pm
Did you try Atmospherica already? It's pretty black. :D
PostPosted: Tue Apr 03, 2012 12:41 pm
Yes, i know this theme but i want a completely black skin. atmospherica has 2 colors :wink:
I want a theme as black as my windows theme :D
but thx for your reply
PostPosted: Tue Apr 03, 2012 12:55 pm
hey you feel like sharing that wall?
PostPosted: Tue Apr 03, 2012 1:42 pm
you can find it here http://vladstudio.com/de/wallpaper/?save_the_planet
PostPosted: Tue Apr 03, 2012 2:34 pm
why not find a theme you really like and colorize it black?
PostPosted: Tue Apr 03, 2012 2:44 pm
well, i had never found a winstep theme i could colorize black. it's weird. no problem with any other color - but black doesn't work.
PostPosted: Tue Apr 03, 2012 3:04 pm
*Didn't* work. Works now. :D
In v12.2, if you chose black as the colorization color, the theme now gets gray-scaled (i.e.; loses all color). Give it a try.
PostPosted: Tue Apr 03, 2012 3:25 pm
jorge is right i had tested it on venom1 before my post and it worked fine.
PostPosted: Tue Apr 03, 2012 3:54 pm
Heh... actually, if you use black, i.e. RGB 0,0,0, it either doesn't work, or it (latest version) turns grey.
HOWEVER, if you input 0,1,0 (or 0,0,1 or 1,0,0) as RGB values, the rendering engine gets fooled, and you get something EXTREMELY close (0.13%) to total blackness.
Cheers mate!
:D
PostPosted: Tue Apr 03, 2012 4:33 pm
thx for the tip mate. it works. thx a lot :D
Users browsing this forum: No registered users and 162 guests
