 Post subject: can't add dock to 2nd of 3 monitors?
PostPosted: Tue May 01, 2012 5:52 pm
I've been trying to add the dock to the 2nd of my 3 monitors. When I click on the second one (correctly identified), and press apply, it shifts to my third monitor.
 Post subject: Re: can't add dock to 2nd of 3 monitors?
PostPosted: Tue May 01, 2012 9:07 pm
1. What version of Nexus are you using?
2. How are you switching the dock to another monitor? Via Preferences or the right click context menu? Is there a difference if you try one way or the other?
PostPosted: Tue May 01, 2012 9:17 pm
I'm using the most recent free version- just installed. (I'm testing this- if it works for me, I'll pay for the pro).
I am trying to switch using Preferences.
I am using DisplayFusion pro for monitor management- that might be it.
PostPosted: Tue May 01, 2012 9:24 pm
Maybe. What exactly does it do?
Anyway, try it with DisplayFusion off, then please let me know. :D
Users browsing this forum: ppetroff60 and 306 guests
