 Post subject: Restart /Shutdown Windows confirmation windows not displayed
PostPosted: Wed May 02, 2012 5:36 pm
When I select Winstep/Exit/Restart Windows and Winstep/Exit/Shutdown Windows, only the very top of the confirmation Window (Are you sure you want to Restart windows? etc) is displayed at the bottom of the screen. There is just enough of the top of the confirmation window to drag it up to display the whole window on the screen to be able to click the Yes or No button.
When I select Winstep/Exit/Exit NextStart and Winstep/Exit/Exit Winstep Xtreme the confirmation Window is displayed in the middle of the screen.
I normally have the 'Auto-hide after a short delay' option selected. However, if I turn this option OFF, then the Winstep/Exit/Restart Windows and Winstep/Exit/Shutdown Windows confirmation Windows are displayed in the middle of the screen as normal.
Is there anywhere that I can change the position of the confirmation Windows in the middle of the screen when I have the Auto-hide option turned ON?
 Post subject: Re: Restart /Shutdown Windows confirmation windows not displ
PostPosted: Thu May 03, 2012 12:31 am
That shouldn't happen. You missed providing a very important detail, however: exactly from *where* are you selecting 'Restart Windows'?
I mean, you can do this from a TON of different places in Winstep Xtreme: from the NextSTART Exit menu, from the Exit menu in the Nexus main context menu, from the Exit menu in the Shelf main context menu, from a internal command placed on a dock or Shelf, etc...
PostPosted: Thu May 03, 2012 11:32 am
From the Winstep button at the very left of the MextStart Taskbar
I have got a Snagit photo of the problem, but I cannot manage to attach it to this post
PostPosted: Sun May 06, 2012 10:08 am
Have you instructions (simple ones please) anywhere that I can look at as that would be a great help
PS great program
PostPosted: Sun May 06, 2012 2:09 pm
Right click anywhere on the dock -> Insert New Dock Item -> Internal Command -> Shutdown -> Shutdown Windows/Quick Shutdown Windows.
The 'Quick' options mean there is no confirmation prompt.
Internal commands can be added to docks, 'Regular' tabs on the Shelf, NextSTART menus and Quick Launch section of the NextSTART taskbar.
PostPosted: Sun May 06, 2012 4:37 pm
Thanks, (and I thought it was going to be difficult ) :oops:
PostPosted: Sun May 06, 2012 4:39 pm
Ehehe. :D
Check out the other available internal commands too (there are about 80+ of them).
Users browsing this forum: No registered users and 291 guests
