 Post subject: Shelf Will Not Stay Above Taskbar
PostPosted: Tue May 08, 2012 3:27 am
I have a bit of a problem, and I hope it can be solved easily. I'm making a new theme, and when I put the shelf on the bottom of the screen it refuses to keep the tabs above the taskbar. It does not matter if it's the Nexstart taskbar or the Windows taskbar.
It was not doing this before, and now all of the themes are doing it. That suggest to me that it's a setting somewhere that got screwed up. I have the box checked to respect space reserved by other docks, toolbars and screen objects, but it seems to have no effect. Image
I made a backup of my settings if you need them: http://dl.dropbox.com/u/2795998/wsbackup.wbk
If you need the theme, I can send it to you.
 Post subject: Re: Shelf Will Not Stay Above Taskbar
PostPosted: Tue May 08, 2012 12:17 pm
Hey Xiandi!
If you enable 'Prevent maximized windows from overlapping the Shelf' in the Shelf's Position tab, does that fix the problem?
PostPosted: Tue May 08, 2012 5:59 pm
Yes, that works. Thank you. :D
Is there a way to allow the maxed windows to cover the shelf and not have the tabs hide behind the taskbar when your windows are not maxed?
PostPosted: Tue May 08, 2012 6:01 pm
My guess is that you found a bug, Xiandi. You're supposed to be able to use one setting without the other.
Problem is that I did a lot of work in the reserve screen space routines in v12.2 so that they work on all monitors of a multiple monitor system, so it's possible a bug crept in.
I'll check into this and, if it really is a bug, I'll fix it for next release.
PostPosted: Tue May 08, 2012 6:10 pm
Thanks for the fast replies, you rock! Image
Users browsing this forum: No registered users and 225 guests
