 Post subject: Nexus shortcut with parameter not working
PostPosted: Thu May 17, 2012 2:38 pm
Hi forum,
I have a Windows shortcut like this (on Windows 7):
Code:
"F:\Program Files (x86)\Adobe\Acrobat 7.0\Acrobat\Acrobat7.exe" /n
...which launches a new instance of Adobe Acrobat every time it is double clicked.
If I drag that shortcut to Nexus, it doesn't work (it only opens the previous instance of Adobe Acrobat instead). Strangely, the very same shortcut DID work with Nexus on Windows XP before.
Any ideas?
Thanks already
David.P
 Post subject: Re: Nexus shortcut with parameter not working
PostPosted: Thu May 17, 2012 5:40 pm
try rightclicking the shortcut, go to compatibility, and set it to xp sp3.
PostPosted: Thu May 17, 2012 6:35 pm
The Windows shortcut works!
Only the Nexus button (cp. screenshot) doesn't.
PostPosted: Thu May 17, 2012 7:04 pm
ok just thought it might be worth a try.
PostPosted: Thu May 17, 2012 9:46 pm
In the Behavior tab of Nexus Preferences, are you sure 'Do not launch multiple sessions' is NOT set?
PostPosted: Fri May 18, 2012 6:58 am
Thanks, that sure enough was it!
However, the german translation is misleading. Instead of "Keine Sitzungen gleichzeitig starten" (????) it should say "Programme nicht mehrfach starten".
Cheers David
PostPosted: Fri May 18, 2012 9:22 am
Hmmm, not sure that is any better...? Unless I got the translation wrong, it could be interpreted as saying not to start multiple programs, even if they are different.
How about 'Sitzungen nicht mehrfach starten' ?
PostPosted: Fri May 18, 2012 2:08 pm
OK, but this could still be misunderstood as "dont start multiple Nexus sessions" (this is actually what I thought that this setting was :? ).
Maybe 'Keine mehrfachen Sitzungen von Programmen starten' would be clearer.
PostPosted: Wed May 23, 2012 7:48 am
Thanks. :D
Users browsing this forum: No registered users and 147 guests
