 Post subject: Recycler not pointing to correct folder
PostPosted: Tue Jun 05, 2012 3:40 am
When I click on the Recycler, in either the Shelf or a dock, it takes me to the C:\ root directory. I'm using Windows XP. Is there a way to redirect this module to open the Recycle Bin? :?
 Post subject: Re: Recycler not pointing to correct folder
PostPosted: Tue Jun 05, 2012 6:16 am
When you right click or when you *left* click the Recycler? Right clicking should open the module's context menu, and left clicking should show the contents of the Recycle Bin in an Explorer window.
PostPosted: Fri Jun 08, 2012 11:06 pm
Right click reveals the context menu; left click opens C:\.
PostPosted: Fri Jun 08, 2012 11:58 pm
rightclick recycler, select dock entry properties make sure item type is set to module and under module make sure recycler is selected.
PostPosted: Thu Jun 14, 2012 4:39 pm
I apologize if anyone thinks I am joking. If anyone can follow, please help me find a way to point the recycler icon's link to the recycle bin folder. ALL settings in NeXuS Ultimate are correctly set. Where can I change the target link? This is a level 3 request. Level one and two cannot solve my problem. :(
PostPosted: Thu Jun 14, 2012 8:04 pm
unless something is messed up in the registry or with the path windows is pointed to for the recycle bin nexus will always point to the recycle bin if the dock entry properties for the nexus recycler icon are set correctly.
PostPosted: Fri Jun 15, 2012 3:48 pm
The action Chucky recommended was intended to determine if you are using the built-in Recycle Bin module *or* a shortcut of the Windows Recycle Bin that you dragged to the dock.
So, when you right click the Recycle Bin in the dock and then select 'Dock Entry Properties', in the dialog that pops up what does it say in the 'Item Type' field?
Also, what is the language of your version of Windows?
Users browsing this forum: Amazon [Bot], Google [Bot], Majestic-12 [Bot] and 106 guests
