 Post subject: Shelf UNDER taskbar? (SOLVED)
PostPosted: Sun Jun 10, 2012 4:14 am
I have a very odd problem, whenever I start up my computer, the "main" shelf is under my taskbar. How do I make it so it goes on top every time? Closing and restarting Nexus seems to fix it until the next startup.
Thanks,
WSNUser
Edit: OK, I think I solved it. I am using Display Fusion, and somehow had put the "main" taskbar on the second monitor and DF's taskbar on my main monitor. When I put the taskbars on their right monitors, everything seems to work now. So, If your having the same issue, check to make sure your taskbars are on the right monitors.
WSNUser :D
 Post subject: Re: Shelf UNDER taskbar? (SOLVED)
PostPosted: Tue Jun 12, 2012 10:17 am
Sounds like the DF taskbar was not reserving screen space.
Users browsing this forum: Amazon [Bot] and 173 guests
