 Post subject: How to hide menus ?
PostPosted: Fri Jun 15, 2012 8:29 am
Hy, (sorry for bad language)
I'm just use four Nextstart menu but i can't find how to completely hide menus when they are not in use ?
I've found an option who say "if they are not in use, close to a small bar", but like that I've a small bar but not completely hide..? (i've set the option who say "menus stay open when launch item" cause it useful for me when i need to launch several programs,mp3,..etc without have to recall the menu all time)..
PS: I have a big request to increase worflow, it would be very interesting if you could find a way to select several elements with a right click'n drag function inside the menu..!! (ex: right click and drag can select several files to copy them or several mp3 to listen them,etc...)
 Post subject: Re: How to hide menus ?
PostPosted: Fri Jun 15, 2012 9:55 am
i've already suggested adding check boxes for shelf folder items, as well as the items in the popup list you get when you click and hold on a folder on nexus or workshelf. is that like what you were thinking?
PostPosted: Fri Jun 15, 2012 10:31 am
Sorry i don't use workshelf so i can't understand what you are talking about but i think if we could have check boxes (or drag to select) to open several files at once in a nextstart menu it would be great!!
PostPosted: Fri Jun 15, 2012 3:36 pm
The main NextSTART menu will close automatically when you click somewhere else on the Desktop. If you want to do the same with your other menus, you will have to do this in the Hotspots that activate them:
1. Open NextSTART Preferences.
2. Go to the Hotspots tab.
3. Select the hotspot that launches one of your four menus.
4. Click the Edit button to open the Hotspot Wizard.
5. Click Next until you reach the page that has 'What title do you want this menu to have?' at the top.
6. Change 'What should NextSTART do when you launch an item from this menu?' to 'Close All Menus'.
7. Repeat for the other hotspots.
If the above does not solve the problem, let me know as it might also have something to do with 'Hotspot groups'.
Users browsing this forum: No registered users and 144 guests
