 Post subject: Winstep disappearing on reboot
PostPosted: Mon Jun 11, 2012 4:34 am
New guy here, love program, but, can anyone tell me why every time I shut down or restart my PC I have to re-install Winstep? Not only re-install, delete previously downloaded program, and then re-install.
Running: Windows 7 64 bit
 Post subject: Re: Winstep disappearing on reboot
PostPosted: Tue Jun 12, 2012 10:13 am
Err, that's definitely not normal, but you don't explain why you have to delete it/re-install after rebooting your system.
What happens when you try to run Xtreme after a reboot?
PostPosted: Tue Jun 12, 2012 11:12 am
Thanks for reply, oops, forgot explanation. And yes, it doesn't seem normal.
At first I though "ok, it closed the program, I'll just to my programs, find it, and open it back up." Which is what I did, but every time I clicked on any one of the folders, it would say I didn't have access to program. And it wasn't one of those "Run as Admin." situations, it pretty much said, Nope, can't do that. Even tried the .exe file...nope.
But, I found if I deleted everything, re downloaded, and re-installed,it would be back to normal. Of, course I had to move everything around again(3 times)So, I just keep it in sleep mode, and it stays activated.
Very frustrating, this is just the type of desktop enchantment I've been looking for.
So, any thoughts? I can provide you with additional info you might need.
PostPosted: Tue Jun 12, 2012 7:05 pm
Can you please post a screenshot of the message you get when you try to run Winstep Xtreme after a reboot?
PostPosted: Wed Jun 13, 2012 9:44 am
Thanks for help.
So, shut down and restarted laptop. Same deal, never seen or had this issue, confusing.
Message after opening
http://bruhn.smugmug.com/Art/Net-Forum-stuff-ignor-please/2377707_9cvWMk#!i=1903277609&k=HWmbcXF
Shown in "All Programs"
http://bruhn.smugmug.com/Art/Net-Forum-stuff-ignor-please/2377707_9cvWMk#!i=1903277537&k=KHtqkTv
PostPosted: Wed Jun 13, 2012 9:49 am
Err, those links are asking me for a password.
Just attach the screenshot JPG files directly to your reply to this message: when you are composing your reply, there is a 'Upload Attachment' section below the main message body editor, click the 'Browse' button then the 'Add the File' button.
PostPosted: Wed Jun 13, 2012 10:05 am
Yep I'm a moron, wrong button. Let's try this.
Nope, still a moron, says images are to big.
message says
"This item referred to by this shortcut cannot be accessed.
You may not have the appropriate permissions"
the other image is showing it in my "All Programs"
PostPosted: Thu Jun 14, 2012 6:18 am
Use this to post your pics. http://tinypic.com/ It's what I use when the images are too large to post directly.
PostPosted: Thu Jun 14, 2012 12:20 pm
avoid tinypic like avoiding the plague. use imageshack or skydrive. tinypic has a nasty habit of removing images for no reason.
PostPosted: Thu Jun 14, 2012 12:26 pm
Thanks, can someone check out these links
In "All Programs"
http://bruhn.smugmug.com/XTRAstuff/Xtra/23557362_2XGLjq#!i=1905325673&k=J7VzRFt
Message I get when I try to open missing program (Winstep)
http://bruhn.smugmug.com/XTRAstuff/Xtra/23557362_2XGLjq#!i=1905325747&k=gZZ89vp
PostPosted: Fri Jun 15, 2012 4:01 pm
Well, as the second image says, you seem to have a user permissions problem on your PC. Hard to tell you exactly what it is since I'm not there to diagnose.
What happens if you go directly to C:\Program Files (x86)\Winstep\ and double click the WinstepXtreme application?
PostPosted: Fri Jun 15, 2012 6:02 pm
Figures it's my machine, icons, program folders,everything goes to un-accessible short cuts or executions. I guess I oughta start googleing for a resolution huh?
One day later, found & resolved issue, good to go, be making purchase soon!!
PostPosted: Sat Jun 16, 2012 8:20 am
New here, too, and just trying to help. I've gotten help via these forums and so want to return the favors, if I can. I won't be at all offended if you simply ignore my suggestions, in which case I don't expect a reply. :)
Did you install the program to an unusual folder rather than the usual Program Files (x86) folder?
Do you use more than one user account on the PC? If so, could you have installed Winstep under a user ID other than the one in which you're trying to use it?
What happens if you bypass the shortcut or is that what you meant by having even tried the .exe? Navigate to the Winstep installation directory (on my PC it's Local Disk (C:) -> Program Files (x86) -> Winstep) and double-click the .exe file (on my PC it's WinstepXtreme.exe.
If you check the security properties of the .exe file (Right-click -> Properties -> Security Tab) do you see the SYSTEM, Administrators, and Users user names? If you click on the Users user name do the permissions show that both Read & Execute and Read are Allowed? It sounds as though the answer to that question, in your case, will be "no." Question is, how did that happen?
Hope this helps. FWIW, I'm using Win 7 64-bit Pro with no issues.
Cheers,
PostPosted: Sat Jun 16, 2012 8:42 am
Hey wbmccarty, thanks for reply,after utilizing this forum, I realized the problem was actually in my user program preferences for "permissions". I adjusted it, and everything was fine. And, yes, I originally installed it without any additional changes.
Thanks again bud
PostPosted: Sat Jun 16, 2012 8:43 am
Excellent! Enjoy!
Users browsing this forum: Amazon [Bot], Google [Bot], GPT [Bot], techlobo and 118 guests
