 Post subject: temp disable attention effect for nextstart
PostPosted: Tue Jun 26, 2012 12:49 pm
i don't know what happened to the thread i created the other day for this, but here we go again. i would like to know if there is any way to disable nextstart from covering part of a fullscreen app when another program is trying to get attention?
 Post subject: Re: temp disable attention effect for nextstart
PostPosted: Tue Jun 26, 2012 12:57 pm
Ah. :oops: No, not currently. :oops:
Hmmm... What does the Windows taskbar do in this case?
PostPosted: Tue Jun 26, 2012 1:16 pm
i'd have to assume the same behavior. i have it set to autohide, but i have it disabled via nextstart.
PostPosted: Wed Jul 04, 2012 11:16 am
as for where to put it easy under nextstart's rightclick menu under disable auto-hide under taskbar settings, and then preferences, taskbar settings, behavior.
Users browsing this forum: Amazon [Bot], ppetroff60 and 257 guests
