 Post subject: Change Separator Spacing
PostPosted: Sat Jul 21, 2012 11:57 am
How to I change separator spacing in any theme ? I would like to know, because for me it seems spacing is too long between the icons.
 Post subject: Re: Change Separator Spacing
PostPosted: Sat Jul 21, 2012 2:32 pm
Try: Preferences --> Appearance --> Icon Spacing.
PostPosted: Sun Jul 22, 2012 5:37 pm
That aslo affects distance between icons. I only want to change distance between separator and icons only, NOT between icons. Even when I do change icon spacing to minimum, then it's still not enough for me. Maybe I could edit some file manually which affets dock's separator spacing.
PostPosted: Mon Jul 23, 2012 7:26 pm
now i don't know if this is something you would like to do but i remove the separators. i think with most themes it gives workshelf a cleaner look.
PostPosted: Mon Aug 13, 2012 6:57 am
Separators always take the same space as a normal icon. There is no way to change that without also changing the normal distance between icons, sorry...
Users browsing this forum: Amazon [Bot], ppetroff60 and 276 guests
