 Post subject: Possible incompatability...
PostPosted: Mon Jul 03, 2006 3:24 pm
Jorge,
I have found that there is an incompatiabliltity with the alpha transparency feature of WSX and CursorXP (from Stardock). When Cursor XP is running, the mouse pointer goes behind anything that has any sort of transparency. For example, with the WSX skin Aero, the mouse goes behind all the modules, WS, menus and the startbar. With the killer old-skool skin "Nextstep", everything is fine.
I am not sure how much effort you want to put into this, but I figured since cursor xp is a "skinners app", the odds of someone have both cursor xp and WSX together are pretty high.
-Paul
PostPosted: Mon Jul 03, 2006 4:58 pm
Works fine for me.
PostPosted: Mon Jul 03, 2006 5:03 pm
Hmm...
It seems to be working for me now... I saw the issue twice, and now it is gone... Kinda like my car, it only works well when it is going into the shop :D
PostPosted: Mon Jul 03, 2006 9:10 pm
So... it is happening again, I was running an OpenGL screen saver and when the desktop reappeared here it what happened:
Note the mouse pointer in the lower right corner.
-paul
PostPosted: Mon Jul 03, 2006 9:43 pm
I must say it is the VERY FIRST TIME I have ever seen the mouse pointer appear behind ANYTHING in all Windows versions, hehe.
Looks more like a bug in Cursor XP.
PostPosted: Thu Jul 13, 2006 2:31 pm
Ack! Confirmed, just seen a message at Wincustomize about a user complaining his Cursor XP icons always go behind windows with alpha transparency (windows skinned by WB). So, it is a CursorXP bug - you'll have to contact Stardock support instead.
PostPosted: Thu Jul 13, 2006 3:21 pm
Well! Glad to know it is not a WSX issue! (and that I am not crazy...)
Users browsing this forum: Amazon [Bot], GPT [Bot] and 211 guests
