 Post subject: Show Folder tab reverts to root [SOLVED]
PostPosted: Thu Aug 09, 2012 9:19 pm
I'm having a little problem here. I'm trying to use the Show Folder tab, but it only wants to show the root of my drive. I want it to show "C:\Users\MyUserName\Desktop\Some Folder" (Names have been changed to protect the guilty), but it keeps showing "C:\" I'm running Windows 7 Ultimate x64, and would like some help.
Thanks, Gamyr
 Post subject: Re: Show Folder tab reverts to root
PostPosted: Thu Aug 09, 2012 9:29 pm
Thanks, Gamyr
it's a known bug in workshelf. however there is a workaround. open the workshelf/nexus preferences, click the docks and shelves tab, click shelf. in the content tab you can edit the folder properties and have it stay the way you want it.
PostPosted: Thu Aug 09, 2012 9:32 pm
ChuckysChild wrote:
Thanks, Gamyr
Exactly where is workshelf for Winstep Nexus Ultimate?
PostPosted: Thu Aug 09, 2012 9:38 pm
Found it. It was under nexus/preferences when you right click an icon on the dock. Also, it works.
Thanks. :D
 Post subject: Re: Show Folder tab reverts to root [SOLVED]
PostPosted: Thu Aug 16, 2012 3:37 pm
I came to the forum looking specifically for this answer, so thank you! Jorge, you might have the forum search parameters set a little too strict. When I searched for "show folder" it responded that my words were too common and returned 0 results.
PostPosted: Fri Aug 17, 2012 6:34 am
The problem is not the forum search parameters. The problem is that PHPBB Search apparently does not allow you to search for an exact phrase. So, when you search for 'Show Folder' what you would get is every single post where the word 'Show' and the word 'Folder' exist, even if not used together.
If too many posts (e.g.; thousands) are returned by a specific search, the search fails and the words in it are marked as 'too common'.
Users browsing this forum: ppetroff60 and 235 guests
