 Post subject: Winstep Doesn't Start Minimized.
PostPosted: Mon Aug 06, 2012 9:42 pm
Whenever Windows boots up and the desktop becomes visible, the Winstep program is also visible from the start. I have the option set to auto-hide Winstep so I'm not sure why it does this. Also when I mouse over the icons they are unresponsive as well. The only way to fix this is to open up the Preferences window and click "ok". After that, the icons are in fact responsive and everything seems fine after that.
This is a rather annoying bug and I am close to actually buying the Ultimate version but I refuse to pay for a buggy application. If you could help me get this fixed then I will highly consider purchasing Winstep as well as tell my family and friends about it.
 Post subject: Re: Winstep Doesn't Start Minimized.
PostPosted: Wed Aug 08, 2012 11:25 am
once winstep starts it looks like something else is stealing focus keeping winstep from collapsing. you need to determine what program is actually the problem.
PostPosted: Wed Aug 08, 2012 8:33 pm
Are you serious? How would I go about determining the problem? All other applications on my PC start up just fine which leads me to believe that the problem lies within Winstep itself.
PostPosted: Mon Aug 13, 2012 6:38 am
What version of Nexus are you running? You can determine that in the top right corner of the About tab of Nexus Preferences.
PostPosted: Tue Aug 14, 2012 3:57 am
12.2 is the version.
PostPosted: Tue Aug 14, 2012 5:40 am
What happens if you exit Nexus and then run it manually by clicking the desktop icon (instead of being run automatically after a reboot)? Does it still refuse to auto-hide?
If so, try the following then: open Nexus Preferences, go to the Advanced tab, click the Troubleshooting Options button. Make a backup of your current settings then click the 'Reset Settings Only' button.
This will reset all settings to default (including the current dock background) but it will NOT change the actual content of your dock.
Now press Ok in Preferences to apply the changes, open Nexus Preferences again, go to the Behavior tab, click the Advanced button and turn the 'Immediately hide or collapse the dock on startup' setting on without changing any other setting. Apply the changes and exit Nexus, re-start Nexus again.
Does it behave correctly this time?
PostPosted: Sat Aug 18, 2012 2:54 pm
No it will auto hide fine after opening up the Preferences window and clicking "Ok" then it auto-hides. The point is that I shouldn't have to open up the Preferences window after every boot-up just to get Nexus dock to behave correctly. As long as this bug remains intact, I won't consider the software worth paying for. When this is fixed and no longer considered an issue then I will happily purchase the software as well as tell my friends and family about it. Thank you for trying to help though, much appreciated.
I decided to give this a try and it still did not work but thank you for the suggestion.
PostPosted: Sun Aug 19, 2012 2:49 am
Sorry, from your reply I couldn't be sure if Nexus auto-hide at startup is malfunctioning even when you run Nexus manually by clicking on icon in the desktop.
Is it?
You see, here Nexus will hide properly when it starts if the 'Immediately hide or collapse the dock on startup' setting is enabled. Nobody else is complaining about this problem either, so whatever is causing this issue on your system is not as simple as you seem to think.
Also, if somebody finds a real bug, or at least one I can reproduce here, I will fix it regardless of that person buying the product or not. Because of this I find it mildly amusing that you trying to 'bribe' me into fixing it. :wink:
PostPosted: Sun Aug 19, 2012 4:03 am
Is it?
I have 'Immediately hide or collapse the dock on startup' checked and upon boot-up the Nexus dock does not auto-hide. After I open the preferences window and click "Ok" the auto-hide works just fine. My point is that I shouldn't have to open the "Preferences" menu just to get the dock to work as it should, therefore it's not actually worth paying for at this point.
Thanks for your time.
PostPosted: Sun Aug 19, 2012 12:39 pm
And you *still* didn't answer the question I already asked twice, so I can't help you either, sorry... :cry:
PostPosted: Sun Aug 19, 2012 12:57 pm
BeKure, restart your comp, but before opening prefs and after everything is completely loaded click on a blank spot on you desktop and see if nexus hides. my roommate has his setup to hide when he clicks on the desktop. since no one else seems to have the problem i have to assume a 3rd party app is the culprit. a lot of times if you uninstall the winstep product and reinstall it will no longer be effected by the particular 3rd party app. also if you haven't tried it yet open you props and change anything, apply, change back, and apply again. too many times with various programs i've seen a feature not working and all i do is change one setting, and then change it back and then it starts working. below are images of my settings.
PostPosted: Sun Aug 19, 2012 9:43 pm
I have Nexus set up to activate when I bump the top left corner of my screen. After my PC boots up, the dock is not hiding the way it should be and it order to get it to hide I have to bump the top left corner of the screen as well as click on a blank spot on the desktop in order to hide it.
So it does in fact hide but only after bumping the upper left corner and then clicking on a blank spot on the desktop.
I have tried reinstalling Nexus and have had no luck.
I have tried changing settings and then changing them back as well with no luck.
PostPosted: Sun Aug 19, 2012 10:19 pm
BeKure, have you set all your settings to the same as mine in all three screens i posted? i noticed you have a few things different than mine in your screenshots.
PostPosted: Sun Aug 19, 2012 11:04 pm
I just set my settings to match yours exactly and still no luck. Thank you for trying to help.
PostPosted: Mon Aug 20, 2012 3:21 am
BeKure, what I recommend you do is to make a video and post the link to it here. If Jorge sees exactly what is going on it might help him more easily determine what's going. If you don't have software to make a video, here's what I use. It has quite a few other features that you should find handy.
http://screencapturer.com/
From what I've read so far, it appears as ChuckysChild said, it's probably a program that you have installed on your computer that is causing the problem. From my experience on this Forum, about 98% of the time it isn't a Winstep product that is causing the problem.
If I had a dollar for every time this happened on this Forum, I would be rich!!
Users browsing this forum: Amazon [Bot], Google [Bot] and 147 guests
