 Post subject: Winstepand screensaver
PostPosted: Wed Aug 15, 2012 2:52 pm
Hello, here a question from a great fan, when i push a button to suspend my 3planesoft screensaver mostly workshelf and sometimes nextstart crash, workshelf gives only a high cpu and nextstart loses it systray, maybe the nextstart issue is windows explorer because this also crashes.
Thanks :roll:
 Post subject: Re: Winstepand screensaver
PostPosted: Wed Aug 15, 2012 4:20 pm
first thing i have to ask is how old is this screensaver application? sounds like it is changing your screen resolution witch can effect other programs gui's running properly. also what version of windows are you running and which version of winstep xtreme are you running.
PostPosted: Wed Aug 15, 2012 5:05 pm
WinStep Xtreme 9.5
3 Planesoft The Forgotten Watch 2.0-11
Microsoft Windows XP Prof Version 2002 SP3
The video mode is the desktop mode.
PostPosted: Wed Aug 15, 2012 5:17 pm
Mondriaan wrote:
WinStep Xtreme 9.5
so i'm right all older software. if you can update to winstep 12.2. should correct the problem.
PostPosted: Wed Aug 15, 2012 5:25 pm
I asked for the reason why it happend you cant assure me that the problem will be solved when i update.
PostPosted: Wed Aug 15, 2012 10:11 pm
actually i did tell you why it's happening. the screensaver is changing your screen resolution when you run it. for the technical details jorge will have to explain that. i know jorge has put a workaround in winstep to keep 3rd party apps from causing winstep to behave like that. so again if you are able to upgrade to the latest version please do so.
PostPosted: Thu Aug 16, 2012 6:30 am
v9.5 was released in May 2009. That's pre-Windows 7 and since then we have over 3 years of constant updates and bug fixes, with *thousands* (literally, just read the history files in your C:\Program Files\Winstep\ folder) of new features and changes in between.
So, which is easier? You updating to v12.2 and see if that fixes the issue you are having, or asking me to remember what *might* be causing an issue with a version that is 3 years old? :wink:
Users browsing this forum: No registered users and 212 guests
