 Post subject: Wallpaper
PostPosted: Fri Sep 21, 2012 1:51 am
Hello
i am new to this page and would like to know how to assign a wallpaper to a winstep theme please, i do not see any option to do this... i figured out how to rename the way the theme names show up in the list of themes but im missing something here,i have a handful of themes that load no wallpaper just stays on the last theme wallpaper...any help?? thank you in advance for any and all help with this. :?
Ed...
 Post subject: Re: Wallpaper
PostPosted: Fri Sep 21, 2012 2:15 am
which themes? they may of been created without wallpaper. also you can open nextstart preferences, themes tab, advanced, and see if you have prevent themes from changing your current wallpaper checked.
PostPosted: Fri Sep 21, 2012 2:34 am
Thanks for your reply,but the checkbox is not checked, and themes are sakura,sirus,ironworks,plasticFanX,I have the wallpaper and thought I could put it in the themes directory and was looking for a .INI OR some sort of config file that I can point the wallpaper to...
i used a text editor to read all the config files in the said theme directory but can not find anything that shows wallpaper..
thank you again
Ed
PostPosted: Fri Sep 21, 2012 2:43 am
now for sirus when i go to it's page it suggest that it doesn't come with the wallpaper.
http://www.wincustomize.com/explore/winstep/594/
out of curiosity i checked the theme i'm currently running and i doesn't come with wallpaper.
PostPosted: Fri Sep 21, 2012 3:00 am
thanks for all the help,i just got the wallpaper from the link...now i just got to figure how to assign it to the sirus theme...
JUST FIGURED IT OUT...THANKS FOR THE HELP
Ed :D :)
Users browsing this forum: Google [Bot] and 137 guests
