 Post subject: way to change all bars at the same time?
PostPosted: Sun Oct 07, 2012 6:00 am
Sorry if this question has been asked before
but I didnt quite know what to search for.
Let's say I have 3 bars and then theme them all differently,
is there a way to tell nexus that I now want all the bars to have the same
theme and styles etc and that from now on when I change the theme, etc, in one
of the bars I want it to change in all of them?
sorry if this is a complete noob question I just didnt know
how to succinctly phrase it
 Post subject: Re: way to change all bars at the same time?
PostPosted: Sun Oct 07, 2012 1:03 pm
wilde first can you not refer to docks as bars? as for what you would like to do i've just gone through all the setting for the dock and do not see any setting for making all docks use the same theme. nice idea to have a setting for those that do use multiple docks. you may want to post the suggestion in wistlist thread.
PostPosted: Sun Oct 07, 2012 3:46 pm
Actually there is a way to do it. I just discovered it.
So I thought I would let you know
that you simply right click a dock and then apply a global theme
from the appearance and sounds menu
I had been looking in the dock properties previously
PostPosted: Sun Oct 07, 2012 3:58 pm
cool. good to know. i had looked in the same place as you did. thanks for posting the info for others.
Users browsing this forum: No registered users and 202 guests
