 Post subject: Re Installation
PostPosted: Sat Oct 27, 2012 8:01 pm
Hello,
Because of an OS problem, I had to clear my HD and reinstall my apps. However, I discovered that although I had my key file and receipt for the purchase of Ultimate, I could not find the file.
After downloading Nexus from the website, I am unable to find how to apply the key file so that I don't have to re-purchase the application.
Help, please...
Thanks,
Jake
 Post subject: Re: Re Installation
PostPosted: Sat Oct 27, 2012 8:13 pm
if it's like the key for winstep xtreme just exit ultimate and leftclick the key, a copy should be put in you license folder automatically.
PostPosted: Sat Oct 27, 2012 8:18 pm
Unfortunately, the file was not recognized by Winstep. Thanks anyway.
J
PostPosted: Sat Oct 27, 2012 8:37 pm
ok try this close winstep, go to
c\users\public\public documents\winstep or nexus depending on how jorge has it for nexus \license and drop you key into that folder. launch nexus ultimate.
PostPosted: Sun Oct 28, 2012 2:32 am
Hi Jake!
Can you please send me a PM with the email address and/or name used when you first registered Nexus Ultimate? Doesn't seem to be the same you used to register to the forum, so I can't find you in the Registrations database.
PostPosted: Fri Nov 02, 2012 1:00 am
Do you have an email address? I prefer not to send my Profile info in a forum.
Thanks,
J
 Post subject: Re: Re-Installation
PostPosted: Fri Nov 02, 2012 10:00 pm
Until you respond, here is my invoice, from January 2011: #4690326.
In fact it was under another email, but as mentioned previously, I will only provide that in an email directly.
Also, please note that I have already written to your Support email directly prior to this email (10/27) on this matter, and still have had no response there either.
Hopefully, this will provide better results for me.
Thanks,
J
PostPosted: Fri Nov 16, 2012 10:30 am
Apologies for the delay... You should have a copy of the original email with your license key by now. :D
Users browsing this forum: ppetroff60 and 318 guests
