Board index : Winstep Forums : General Discussion  [ 20 posts ] Go to page Previous  1, 2
 Post subject: Re: Winstep Doesn't Start Minimized.
PostPosted: Tue Aug 21, 2012 2:22 am
Windy wrote:
BeKure, what I recommend you do is to make a video and post the link to it here. If Jorge sees exactly what is going on it might help him more easily determine what's going. If you don't have software to make a video, here's what I use. It has quite a few other features that you should find handy.
http://screencapturer.com/
From what I've read so far, it appears as ChuckysChild said, it's probably a program that you have installed on your computer that is causing the problem. From my experience on this Forum, about 98% of the time it isn't a Winstep product that is causing the problem.
If I had a dollar for every time this happened on this Forum, I would be rich!!
Ok here you go.
http://youtu.be/XjCa8Aip50I
PostPosted: Sat Sep 01, 2012 7:14 pm
Did the link to the video not work?
PostPosted: Tue Nov 13, 2012 11:48 pm
Never mind because it never worked right anyhow. I'm not sure if you ever took a look at the video I posted but it's all good. I'm running Windows 8 now and the start screen looks a lot cleaner than what I tried to accomplish with the Nexus software and it's a lot less buggy.
Anyhow good luck with your software. It just wasn't for me.
Take care.
PostPosted: Wed Nov 14, 2012 1:16 am
I looked at the video and couldn't make out what the problem was. I figured that Jorge would be able to figure it out and address the problem. I don't know why he never replied.
BTW, I guess you missed the thread on Windows 8. I'm not a fan and apparently so are a lot of posters here. Check it out. viewtopic.php?f=2&t=8509&start=0
PostPosted: Wed Nov 14, 2012 2:29 am
I personally got bored with Windows 7 and I appreciate the speed that is associated with Windows 8 so I will be sticking with it. I really am enjoying my new speedy OS. To each his own I guess.
Thanks for at least responding. Take care.
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 20 posts ] Go to page Previous  1, 2
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 218 guests
