Board index : Winstep Forums : Off Topic  [ 2 posts ]
 Post subject: Windows 8
PostPosted: Fri Nov 16, 2012 6:07 pm
Three boxes later :shock: after the one I had for 10 years blew up :( (not kidding), need to know whether Winstep and Windows 8 are compatible.
If so, those using Windows 8, how did you set yours up?
Thanks.
Mist
 Post subject: Re: Windows 8
PostPosted: Fri Nov 16, 2012 10:46 pm
Hi Mist!
They are compatible, but because Microsoft actually *removed* the glass blur functions from Windows 8, the Glass Blur function that would automatically blur the semi-transparent part of dock backgrounds, etc, will not work.
Also, since Microsoft also removed the Start Menu code, the 'Show Start Menu' internal command won't work either.
As far as I know those are the only/major problems with Windows 8.
Post new topic Reply to topic Board index : Winstep Forums : Off Topic  [ 2 posts ]
Users browsing this forum: No registered users and 51 guests
