 Post subject: No transparency in Windows 8
PostPosted: Tue Nov 27, 2012 8:21 pm
Hey guys, new buddy around.
I cant get last nexus version to show itself as it should. Themes apply with sharp edges and no transparency, my english is rude so I`ve uploaded a screen of the problem.
http://imageshack.us/photo/my-images/22 ... bitss.png/
 Post subject: Re: No transparency in Windows 8
PostPosted: Tue Nov 27, 2012 8:33 pm
you can thank microsour for that. they removed several gui features from windows with windows 8.
PostPosted: Tue Nov 27, 2012 9:22 pm
So there is no fix for that? Ntch, I really wanted to use this dock. Any alternative?
PostPosted: Tue Nov 27, 2012 9:38 pm
kilowatt, you may want to checkout virtualcustoms.net and creativx.net
PostPosted: Wed Nov 28, 2012 4:40 pm
Open Nexus Preferences, go to the Effects tab and disable the 'Enable Vista Glass blur effect for semi-transparent dock backgrounds'. Alternatively, right click the main Nexus dock icon, select 'Effects' from the right-click menu that pops up, then click the 'Disable Background Blur Effect'.
The problem is that Microsoft, in their infinite wisdom (not!), removed the code that blurred semi-transparent backgrounds under Windows 8, making it display a solid white instead.
Disabling the background blur option in Windows 8 will remove the solid white, which will become transparent instead.
Users browsing this forum: Bing [Bot] and 137 guests
