 Post subject: Net Meter Issue
PostPosted: Sat Jan 12, 2013 1:38 am
Was wondering if anyone else has run into this issue, the 'Net Meter' module reports "No Network Interface Cards Detected"...
Any one have any ideas?
Win7 Ultimate 64bit...
Previously it was working....
 Post subject: Re: Net Meter Issue
PostPosted: Sat Jan 12, 2013 5:31 pm
Have you tried unchecking the 'Show physical network adapters only' option in the Net Meter Settings panel?
PostPosted: Tue Jan 15, 2013 1:28 pm
Yes and all it has is an "AVAST! Firewall NDIS Filter Miniport" listed
PostPosted: Tue Jan 15, 2013 4:23 pm
And you get nothing if you select that?
I would like to help further, but since it was working previously that seems to be a system specific issue - you need to figure out what changed in your system that caused this issue.
The Net Meter simply asks Windows to enumerate all available network cards, and then uses the list of provided by the OS. Thus, the problem is in Windows itself and not the Net Meter.
Users browsing this forum: ppetroff60 and 82 guests
