 Post subject: Newbie with a Question?
PostPosted: Sun Mar 17, 2013 8:49 am
HI everyone, can someone give me some advice please.
It seems that I have 2 (top) Docks running and 2 speaking Clocks, irritating,
I have looked in my start-up file and have "Nexus" and "NextStart" enabled and presume that one of these is causing the problem, but not sure which one.
Any Help would be appreciated.
Also unable to Paste to this Topic from the ClipBoard??
Len
 Post subject: Re: Newbie with a Question?
PostPosted: Sun Mar 17, 2013 11:47 am
sounds like you installed the stand alone nexus and winstep xtreme that comes with nexus. in the process you managed to somehow cause both instances of nexus to run. my suggestion is uninstall both programs in the order you installed them, restart, and install xtreme again.
PostPosted: Sun Mar 17, 2013 3:50 pm
Thanks will try that later and let you know result
Len
PostPosted: Mon Mar 18, 2013 6:00 pm
Hi again, could not find a way to uninstall Nexus Dock, so disabled "Nexus" in the start menu.
Now only one Dock and Clock working
Users browsing this forum: GPT [Bot] and 140 guests
