 Post subject: New theme problems in workshelf
PostPosted: Fri Sep 15, 2006 9:42 pm
Hi, i have tried to install some themes, but for some reason, they dont work, all i get is an old standard skin, why cant i get in decent skins to work like Aero?
PostPosted: Fri Sep 15, 2006 10:36 pm
Probably because you are still using Winstep Full Pak (NextSTART v3.41 and WorkShelf v1.90) and the newer skins were made for the newer Winstep Xtreme (NextSTART v4.0 beta and WorkShelf v2.0 beta), which you can download from
http://www.winstep.net/xtreme.zip
Are you a registered user, willz?
Either way, you can get more information about Winstep Xtreme and how it relates to Winstep Full Pak here:
http://www.winstep.net/news.asp
PostPosted: Sat Sep 16, 2006 9:57 am
Thanks, i think i am using the latest version though :s.
Yea i am a registered user, i thought you had to :s
Ah, it's working now.
Is there a theme that makes the start bar at the bottom look like Windows Vista RC1, you know, so it has an orb instead of that crappy looking old fasioned Aero bar.
PostPosted: Sat Sep 16, 2006 8:45 pm
Good! :D
There is no such theme, but since I'm actually the one who made the Aero theme (well, ahem, ported it is closer to the truth :wink: ), I will probably update it to display the orb before the next release of Winstep Xtreme - provided Microsoft doesn't jump on my back because of it, of course.
PostPosted: Sun Sep 17, 2006 10:53 am
hehe, i hope microsoft doesent, there so stupid lol, it would also be good if i could get rid of the normal taskbar under the winstep one, you know, the stock windows one, coz when you press the start button it's still there, when i want ti get rid of it if thats possible.
Users browsing this forum: Amazon [Bot] and 209 guests
