 Post subject: Is winstep xtreme compatible windows 8.1
PostPosted: Wed Dec 11, 2013 11:58 am
:shock: I wish to upgrade to windows 8.1, and winstep is already in my windows 8. Update as it is or i have to unnistall winstep before update windows 8.1. Thanks.
 Post subject: Re: Is winstep xtreme compatible windows 8.1
PostPosted: Wed Dec 11, 2013 2:23 pm
you should be just fine updating to 8.1 without uninstalling winstep.
PostPosted: Wed Dec 11, 2013 3:36 pm
Like chucky said, you *should* be fine just updating without uninstalling.
I only say "should" because I keep as far away from Win8 as I possibly can, so I don't have any experience with it (nor do I want to).
PostPosted: Thu Dec 12, 2013 12:56 pm
I switched from 8 to 8.1 and WinStep is working fine for me.
PostPosted: Sat Dec 14, 2013 6:41 am
Hear, hear! You have no idea the problems I've had trying to educate certain people about the ills of Win8. Did they listen?...of course not. Now after using it for a while, all of them are trying to get rid of their pc's (without taking a total loss) but can't.
PostPosted: Sat Dec 14, 2013 3:57 pm
i have said it more times than i can possibly count when you have issues with the look and feel of a os look to the theming community. there are apps out there now to fix just about everything wrong with windows 8 and 8.1, including apps so you land on the desktop when starting up instead of landing on metro. i am planning in the next few weeks on dual booting both 7 and 8.1 and slowly customizing 8.1 to have the best of itself and win 7. checkout deviantart, virtualcustoms, tweaktown, etc.....
PostPosted: Sun Jun 22, 2014 5:09 pm
O.K. After Extensive Testing In VM I've Finally Installed Windows 8.1.1 On My Machine.
Main Theme Ultimate Clean-Updated By gsw953 http://www.megathemer.net/showthread.ph ... an-updated
Wallpaper One I Just Found Online
Token Light Cursors By outofashion http://outofashion.deviantart.com/art/t ... -214337908
7tsp Icon Pack - 7tsp gray8.1 token icon pack.7z Not Having Any Luck Finding The Author To Give Proper Credit To
Sounds - Stardock Object Desktop SoundPackager Using The Metroid Soundpack By ZeaPlanet
Tabbed Windows Explorer - Clover http://ejie.me/
AeroGlass 1.2.5 + Symbols Pack http://www.msfn.org/board/topic/170850- ... win81-125/
OldNewExplorer http://www.msfn.org/board/topic/170375- ... win78-one/
StartIsBack 1.6.2 http://startisback.com/#download-tab Black Glass Enhanced v0.5 By curiouso9 http://curiouso9.deviantart.com/art/Bla ... -156752713
Moo0 Transparent Menu 1.20 http://www.moo0.com/?top=http://www.moo ... arentMenu/
I Thank Enveryone That Contributed To Making It Possible To Theme Windows 8, 8.1, 8.1.1
A Special Thanks To gsw953 For A Simply Fantastic Theme
A Special Thanks To Lamia For All The Help He Gave Me Getting Up And Running
http://vimeo.com/98773631
Users browsing this forum: No registered users and 151 guests
