 Post subject: WinStep, Kaspersky not working
PostPosted: Thu Dec 19, 2013 7:14 am
Hi
Yesterday I installed WinStep Nexus Extreme. And now I can't click on the Kaspersky icon in the system part of the taskbar (right bottom). And my Internet stopped working. After restarting Kaspersky it's fine again. I guess it's because of WinStep :cry:
Any idea, similar experience?
 Post subject: Re: WinStep, Kaspersky not working
PostPosted: Thu Dec 19, 2013 1:29 pm
try a different theme for winstep. i had kaspersky installed in the past using winstep xtreme and never had a problem clicking it's systray icon in nextstart.
PostPosted: Thu Dec 19, 2013 8:47 pm
Doesn't work with other themes.
PostPosted: Thu Dec 19, 2013 10:22 pm
then it has to be the kaspersky icon that's the problem.
PostPosted: Fri Dec 20, 2013 1:22 pm
Excuse me but I still haven't understood what's Nexus got to do with the system tray and its icons. Nexus will just create a dock on some side of the desktop. Why would it be not allowing you to click on *any* taskbar icon?
PostPosted: Fri Dec 20, 2013 3:16 pm
shut down winstep, click the kaspersky icon in the WINDOWS systray and see if it launches. let us know.
PostPosted: Wed Feb 12, 2014 5:10 pm
Kaspersky Internet Security 2014 had some bugs at initial release. This might be attributed to those issues. I use it and sell it to client. But I will say to my knowledge, it has never had an issue with WinStep's software.
I use the ultimate version, and I chose to add a custom icon to KIS on the Nexus Dock. Do a Google image search for Kaspersky icon, and you should be able to find something that'll work for you.
This is the icon I chose to use:
PostPosted: Wed Feb 19, 2014 4:29 am
same issue here ...
no access to "Kaspersky Internet Security" via the "K-Symbol" in systray. Neither right click nor left mouse-click has any affect. The reaction of the other icons are normal, no probs with them. :shock:
Win 7 Ultimate/64bit
Edit: forgot to mention: Kaspersky Internet security version 14.0.0.4651(d)
PostPosted: Wed Feb 19, 2014 12:41 pm
TwinBit wrote:
same issue here ...
is this clicking the win 7 taskbar icon like i asked?
Users browsing this forum: Amazon [Bot], ppetroff60 and 121 guests
