 Post subject: Open multiple items
PostPosted: Sat Mar 29, 2014 9:56 am
Hello,
I would like to open multiple items of the same type of dock with the middle mouse button (the wheel). For example, opening gogole chrome 2 or 3 times.
The Windows taskbar can.
How I can configure it?
Thank you,
regards
 Post subject: Re: Open multiple items
PostPosted: Sat Mar 29, 2014 1:41 pm
Actually, I'm not very sure about the "middle click" detail. I don't think there is such a setting.
However, you can configure a shortcut to open a new session for all clicks on it. There's a setting, but bear in mind that it could also involve a special switch in the command line. I don't know about Chrome, I try to stay away from Google products if I can, but Firefox, for example, needs the "-P -no-remote" switch, so that it can open a new process and select a different profile.
PostPosted: Sat Mar 29, 2014 6:01 pm
I assume you have the 'Do not launch multiple sessions' setting enabled. In that case, you can force launching multiple sessions the same way you can with the taskbar: pressing SHIFT when you left click on the dock item.
PostPosted: Sun Mar 30, 2014 6:13 pm
Hello,
Thank you. With the SHIFT key works for me.
regards
Users browsing this forum: Amazon [Bot], Google [Bot] and 203 guests
