 Post subject: Possible to alter "Open Folders As Menus" Settings?
PostPosted: Mon May 26, 2014 1:10 am
I have been using Winstep Xtreme as my primary file management system and have a question about the following setting:
Preferences / Docks & Shelves / Shelf Properties / Behavior / Advanced Behavior Settings /
"Always open folders as menus (you can also do this by left clicking an icon and holding)"
Is it possible to use this feature in an inverted state and/or assign a new shortcut, for example:
A(Default): Left Click to open folder, Left Click & Hold to open menu
B: Left Click to open menu, Left Click & Hold to open folder
C: Left Click to open menu, Middle Click to open Folder
And also, is there a setting to alter the delay time of Left Click & Hold?
I have altered other aspects of my docks & menus using the theme setting files (*.nxs, *.wst, etc.) and am comfortable altering these or other application related files, however, I was unable to locate the settings mentioned above.
 Post subject: Re: Possible to alter "Open Folders As Menus" Settings?
PostPosted: Mon May 26, 2014 1:51 am
No, that is not configurable by any setting; I am quite sure it's hardcoded, as well as the delays.
However, it's an interesting proposition. I'm sure our good programmer will notice this and add it in his "to do" lists.
Users browsing this forum: Google [Bot] and 103 guests
