 Post subject: Systray Position
PostPosted: Mon Aug 11, 2014 9:24 pm
Hi,
I'm running with a detached systray on the bottom right of the screen. As I'm using a laptop with various monitor sizes depending where I am I can lose the systray if I've pulled it to the bottom corner of a large monitor, then connect to a smaller one. Can the systray position be set based on a screen position rather than screen coordinates ('Bottom-Right of primary screen' for example) in a future release? Also, did it work with screen positions in a previous version of Nextstart or am I dreaming that?
Also, on the systray - I've noticed that it sometimes draws the systray icons 'under' the systray button, though I don't know what causes it and a couple of hide/show cycles seems to correct it.
Thanks,
Pete
Users browsing this forum: Google [Bot] and 185 guests
