 Post subject: Windows taskbar
PostPosted: Mon Dec 01, 2014 12:54 pm
Hi, sorry for my english..
I need help ... I installed winstep nexus
Now I work with the windows taskbar always hidden ...
when I need to turn it on, I have to go into settings and enable it manually winstep ... Is there a way to activate a keyboard shortcut to activate / hide windows taskbar type (Ctrl + *)?
 Post subject: Re: Windows taskbar
PostPosted: Mon Dec 01, 2014 3:21 pm
Right click on the dock -> Insert New Dock Item -> Internal Command -> Desktop -> Hide/Show Taskbar.
This will add an Internal Command shortcut to the dock which will toggle the taskbar on/off when clicked on. You can now also associate a hot key (keyboard shortcut) to this item by right clicking on it and selecting 'Dock Entry Properties'.
PostPosted: Mon Dec 01, 2014 3:40 pm
thank you so much ... you are a god :D :D
PostPosted: Mon Dec 01, 2014 3:52 pm
Don't think my ex would have agreed with you on that one, but thanks anyway! :wink:
PostPosted: Mon Dec 01, 2014 6:27 pm
:D
Users browsing this forum: Apple [Bot] and 88 guests
