 Post subject: BitsDuJour Xtreme Activiation
PostPosted: Tue Feb 03, 2015 1:06 pm
I purchased Xtreme back a couple weeks ago, and I received my activation code, but I've searched all over the software and internet trying to figure out where to put this code to unlock it. Can someone tell me where the activation located? I checked Preferences and About, and there's no button or form fill to key this code into the software.
Thanks.
 Post subject: Re: BitsDuJour Xtreme Activiation
PostPosted: Tue Feb 03, 2015 7:05 pm
There should be a Registration tab (it will disappear once the software is registered).
What does it say at the bottom of the About tab, in the scrolling letters?
PostPosted: Tue Feb 03, 2015 8:39 pm
As it scrolls by...
"Everybody loves a pretty face! Want a desktop that becomes the envy of whoever looks at it?" OR "Liked this software? Then Winstep Xtreme/Nexus Ultimate will simply blow your mind!"
I ordered it on 1/8/15 & my order # was BDJ-xWxcmR.
Thanks.
Tom
PostPosted: Wed Feb 04, 2015 12:18 am
Ok, if it says that then you are using the free version of Nexus.
What you need to do is download Winstep Xtreme from the Winstep web site and install that instead.
PostPosted: Wed Feb 04, 2015 2:17 am
Will do. I'll give that a try in the morning. Thanks for your help. :D
Users browsing this forum: Amazon [Bot], Google [Bot] and 173 guests
