 Post subject: Crashes when rightclicking Shelf or Dock
PostPosted: Sat Oct 10, 2015 4:46 pm
Unfortunetely I often experience crashes when right clicking a dock- or shelf-item. What can I do ?
Eventlog:
Name der fehlerhaften Anwendung: WorkShelf.exe, Version: 15.9.0.1081, Zeitstempel: 0x560cee58
Name des fehlerhaften Moduls: ntdll.dll, Version: 10.0.10240.16430, Zeitstempel: 0x55c599e1
Ausnahmecode: 0xc0000005
Fehleroffset: 0x0007d08b
ID des fehlerhaften Prozesses: 0x1e44
Startzeit der fehlerhaften Anwendung: 0x01d10376965fc76b
Pfad der fehlerhaften Anwendung: C:\Program Files (x86)\Winstep\WorkShelf.exe
Pfad des fehlerhaften Moduls: C:\WINDOWS\SYSTEM32\ntdll.dll
Berichtskennung: a957636b-7d5f-43b0-a215-183eed3971cb
 Post subject: Re: Crashes when rightclicking Shelf or Dock
PostPosted: Sat Oct 10, 2015 5:52 pm
Usually those happen because of a buggy 3rd party shell context menu extension. Try setting WorkShelf NOT to display full context menus and see if the crashes go away.
PostPosted: Sat Oct 10, 2015 6:45 pm
That did the trick, thank You :-)
Users browsing this forum: No registered users and 223 guests
