 Post subject: Control Panel Items
PostPosted: Tue Oct 27, 2015 12:50 pm
Is there a way to refresh "All Control Panel Items". Only two show up through winstep.
If I click on "Computer", then "All Control Panel Items", only two show.
If I click on "Settings", then "Control Panel", all show up.
 Post subject: Re: Control Panel Items
PostPosted: Tue Oct 27, 2015 2:34 pm
Are you referring to the NextSTART menu and is that a Windows 10 system you're running under?
PostPosted: Tue Oct 27, 2015 11:06 pm
Yes, NextStart Menu. Running Windows 10. Theme is DarkTech.
PostPosted: Sun Nov 08, 2015 4:29 pm
Oh well...
PostPosted: Sun Nov 08, 2015 6:22 pm
Sorry... the reason I knew what you were refering to (i.e.; NS menu + Windows 10) is because I had already noticed something odd about a 'Control Panel' item appearing in the Desktop menu under Windows 10. In fact, it should not appear at all, and IIRC it isn't always there when you open that menu.
Anyway, the issue is a mix of Windows 10 being its usual odd self and a 32 bit vs. 64 bit issue. I'll look into it before the next release.
PostPosted: Mon Nov 09, 2015 1:59 am
OK, thank-you Sir! :)
Users browsing this forum: Amazon [Bot], GPT [Bot] and 151 guests
