 Post subject: What is on your snapshot exclusion list?
PostPosted: Tue Oct 31, 2006 9:03 am
I really need to have an idea of what programs are conflicting with the task snapshots, so NextSTART can ship with a default exclusion list...
So, what applications are currently on your snapshot exclusion list? When providing them, please specify how you've got them described on the list (executable name and/or application name used).
Thanks in advance!
PostPosted: Sat Nov 04, 2006 5:07 pm
Hey Jorge:
Good idea: my exclusion is "tbrush.exe" (executable).
Thanks. John
PostPosted: Sun Nov 05, 2006 1:08 am
Thanks! :D
It would also be a good idea to explain why you put those applications there - what ill effects the snapshots had on them.
I'm adding mine to the list:
wmplayer.exe
Because taking the snapshot 'confuses' with the video hardware overlay, causing the video to overlap windows on top of the media player.
PostPosted: Sun Nov 05, 2006 3:33 am
Go here:
http://forums.winstep.net/phpBB2/viewto ... sted+brush
PostPosted: Sun Nov 05, 2006 4:24 pm
I've the following on my exclusion list
the basic MS office apps
- powerpnt.exe
- winword.exe
- excel.exe
GoogleEarth (googlearth.exe) - can't quite remember why I put this on the list
QEmu (qemu.exe) - virtual machine
-RikD
PostPosted: Sun Nov 05, 2006 4:39 pm
STRANGE:
I have never had any problem with Media Player, Word or Excel !!! :? :?
John
PostPosted: Sun Nov 05, 2006 7:18 pm
With Media Player you probably have the video overlays disabled, otherwise I'm sure you would have noticed the problems...
With the Office applications, however, I have no idea what the problem might be... :roll:
PostPosted: Thu Nov 09, 2006 9:17 am
Not sure what problem is with office apps (working with Office 2003) - but I have big problem when working with tables in particular - and sometimes imported pictures.
Example is when looking at a particular presentation in power point which has our company logo, and a simple table in it. I can see the original slide, then overlayed but offset a little is another copy of the logo and the table lines.
This happens in Powerpoint, Word and Excel - and a new one Visio.
Also - if I alt-tab to something else complely different, e.g. firefox, then the same info is overlayed on that.
Disabling snapshots fixes :)
RikD.
Users browsing this forum: Google [Bot] and 211 guests
