 Post subject: CD/DVD no longer works
PostPosted: Fri Feb 12, 2016 4:16 pm
After updating to the latest version 16.02.1026 I can no longer open and close the CD/DVD tray. How do I revert back to the older version without messing up my settings ?
 Post subject: Re: CD/DVD no longer works
PostPosted: Fri Feb 12, 2016 4:19 pm
Anyone else seeing this?
Keeps working fine here.
Gabe, is there an error message?
PostPosted: Fri Feb 12, 2016 5:04 pm
Working now. But every time I open or close the tray I have to close a pop up error window that says sorry, unable to eject media on drive D:(8/87) or
sorry, unable to load media on drive D: (4/87)
PostPosted: Fri Feb 12, 2016 5:09 pm
The first time I clicked, I got the same basic error message (with different numbers in the parentheses), but clicking a second time worked with no error messages. I clicked it a few more times just to be sure.
So I tried exiting Workshelf and restarting it, still no error message. So I completely exited Winstep and restarted it. Still nothing. The only thing left is to reboot. Not gonna do that until at least Monday because I'm going to be out of town all weekend.
PostPosted: Fri Feb 12, 2016 5:13 pm
Okay, I installed the silent update, and still no error message.
PostPosted: Fri Feb 12, 2016 5:37 pm
The numbers in parentheses are *crucial*. It's them that tell me where the function failed and why it failed.
87, for instance, means the function is returning ERROR_INVALID_PARAMETER when issued a IOCTL_STORAGE_EJECT_MEDIA or IOCTL_STORAGE_LOAD_MEDIA command.
No idea why though.
PostPosted: Sat Feb 13, 2016 3:18 am
Sucks , I liked the old discs open & close. Can I revert back to the old version?
PostPosted: Sat Feb 13, 2016 3:22 am
No, you cannot.
You can help me figure out what the possible problem is so I can fix it, though. :wink:
For instance, you can tell me if having media in the drive when you open and close the CD tray makes a difference or not.
PostPosted: Sat Feb 13, 2016 4:25 am
No, you cannot.
No disc in drive though I will try tomorrow,Also will try to reboot again. Shutting down tonight. Start up tomorrow. Fresh
PostPosted: Sat Feb 13, 2016 12:53 pm
PostPosted: Sat Feb 13, 2016 4:00 pm
Start up today no change. Put a cd in opened and closed the tray twice, no change. Played the cd, then opened and closed tray, no change same error message. Running windows 10 pro 64 bit
PostPosted: Sun Feb 14, 2016 12:26 am
I also have another drive it's usb, so it can only open the drive. Tried that one and it opened it and still have the same error message.
PostPosted: Sun Feb 14, 2016 4:10 am
An alternative to these problems with CD Tray is using NirCmd.
You make a shortcut of the main program (in the same folder or somewhere saved), plug in the modifiers in the properties of the shortcut, name the shortcut to your liking "Eject" for instance, customize the icon and put that in your tray.
I use this to control my volume for my system and muting. Though I haven't used a cd/dvd in years, this used to work just as well for that where needed.
Go to NirCmd Website
Windows: Ctrl Click to open in new tab.
Mac: Command Click to open in new tab.
Not pushing aside Jorge or anything. : - ) Just an alternative to relieve some of the pressure perhaps.
You can use it for a crap load of tasks. It's pretty nifty really.
PostPosted: Mon Feb 15, 2016 6:03 am
Okay, we had a power outage and I don't have my UPS hooked up, so I got a reboot. The numbers in parentheses are 8/1816.
PostPosted: Mon Feb 15, 2016 6:16 am
I clicked it a second time to close and git a 4/1816.
Users browsing this forum: adonis, Bing [Bot], Google [Bot] and 127 guests
