 Post subject: Rocketdock-Stacks Docklet - view folder with just one click
PostPosted: Sun Mar 13, 2016 3:47 pm
First request 8)
Once you have run out of ideas for this magnificent program, could you look at duplicating a feature I find useful from Rocketdock
I am running Winstep Extreme, on windows 10, and a minimum setup of Rocketdock with the addon of 'Stacks Docklet' This allows me to view folders like this
(now chances are you are going to say winstep already does this, well I have only being using your software for four years(?) so still learning. )
Sorry thought I had posted this in 'wish list '
 Post subject: Re: Rocketdock-Stacks Docklet - view folder with just one cl
PostPosted: Sun Mar 13, 2016 4:24 pm
You're using Extreme. Do you use the Workshelf portion at all? In Workshelf, for a folder tab, if you double-click, it expands the tab to see the entire contents. Try it. It might be your solution.
PostPosted: Thu Mar 17, 2016 8:31 am
Divingbrit, look at this video https://www.youtube.com/watch?v=laNfsIeJebY which is also posted as the Highlighted Video on the Winstep Themes page. http://www.winstep.net/themes.asp
It shows WorkShelf being used. WorkShelf is set to display the hidden desktop icons via a bump at the top of the monitor that appears to fulfill what you're trying to accomplish. As you'll see in the video, cycling through the icons can be done easily. It is accomplished by using the mouse wheel.
If you need help setting it up to use it in that manner, please don't hesitate to ask how.
P.S. Be patient, the part I'm referring to is near the latter part of the video. :)
PostPosted: Thu Mar 17, 2016 7:32 pm
Users browsing this forum: Google [Bot] and 231 guests
