 Post subject: Hotspot Menu Files Show as Question Mark
PostPosted: Tue Apr 05, 2016 4:43 pm
Hi Jorge. There are a couple of files that I happened to come across that show up in my Hotspot menu (via bump) as a question mark. They've been there for years but I haven't accessed that part of it until now.
I have a ton of music files in the same folder that show perfectly fine.
I'll send them to you so you can check them out. One is a music file and the other is a link.
Please let me know whether or not you receive the files. Thanks.
 Post subject: Re: Hotspot Menu Files Show as Question Mark
PostPosted: Tue Apr 05, 2016 5:06 pm
Hmmm, not sure sending them to me is going to shed any light on this.
What happens if you put shortcuts to those files on a dock or the Shelf?
PostPosted: Tue Apr 05, 2016 8:18 pm
I just sent you one of the files right before reading your reply. This is really odd!
I tried to send you the link but my e-mail client said there is a problem with it and gave me the option to send only the music file or close it.
Here is the link/file I tried to send you. http://red.clientapps.yahoo.com/customi ... aunchcast/
This is also really odd. I made a shortcut of both within the folder and then dragged them to the dock. They both show a question mark. However, the link/file opens to the page, but I get an error message for the music file. :?
Here is the error message I get for the music file.
PostPosted: Sun Apr 10, 2016 2:17 pm
Jorge, have you come up with any solutions and why those question marks appear in the hotspot context menu (via a bump) and on the dock after dragging the shortcut for them to the dock?
Also why the link works on the dock but the music file does not when both display a question mark?
Users browsing this forum: No registered users and 261 guests
