 Post subject: restore does not restore everything
PostPosted: Mon Jul 11, 2016 8:19 pm
with winstep ultimate 16.6 restore works but the themes when making the backup are not restored.
eg
first make a backup
then change to a different theme
then do a restore
everything is restored exept for the previous themes which were active on each dock.
especially irritating when you have different themes per dock and accidently hit the change theme button.
after that you can change every theme back to the one it was before MANUALLY.
please fix this backup/restore thing so it backups everything, also the themes per dock.
 Post subject: Re: restore does not restore everything
PostPosted: Mon Jul 11, 2016 8:47 pm
Ok, managed to reproduce here when using different themes for each dock, so I can confirm it is a bug.
However, here is a quick work-around for you: restore the theme twice.
First time you restore you get the docks showing the global Nexus theme as you pointed out, but immediately restore the same backup again and this time the individual themes will be properly applied.
Users browsing this forum: Amazon [Bot], winstep and 183 guests
