Board index : Winstep Forums : General Discussion  [ 19 posts ] Go to page Previous  1, 2
 Post subject: Re: Dock popping up when a program is flashing for attention
PostPosted: Fri Oct 07, 2016 12:27 am
Jaidek wrote:
Was this feature ever implemented in Nexus? I would like to disable windows notifications from unhiding my dock and I can't seem to find the setting in any of the proposed locations.
No, it wasn't.
This topic is from 2012, just after the v12.2 release. In the next two years there were no updates and I ended up forgetting all about this thread.
That's the bad news. The good news is that I just added that setting for the next release.
It will be in the Activation Settings dialog of the Behavior tab as 'Activate if hidden when an application in the dock requests attention' and the setting will be enabled by default.
PostPosted: Fri Oct 07, 2016 11:59 pm
Great! Thanks for adding in this feature! :D
PostPosted: Sat Apr 04, 2020 2:09 am
Hello, I'm looking for this setting you've added and can't seem to find it there. Has it moved?
PostPosted: Sat Apr 04, 2020 2:50 am
No.
Dock Properties (or Preferences if you are running the free version of Nexus) -> Behavior tab -> Activation Settings button -> 'Activate if hidden when an application in the dock requests attention' setting on the middle-right side of the panel.
Make sure you are running v19.2 or later.
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 19 posts ] Go to page Previous  1, 2
Users browsing this forum: No registered users and 192 guests
