 Post subject: ISGROUPS Question
PostPosted: Tue Nov 01, 2016 4:11 pm
I am administering an exam with partial credit items. All items will utilize the same partial credit model, but the number of response options varies from 5 to 8. Do I need to assign items to different ISGROUPS depending on the number of response options, or can I group them all together? Many thanks.
 Post subject: Re: ISGROUPS Question
PostPosted: Tue Nov 01, 2016 5:18 pm
You're posting on the wrong forums/website/company.
What you are looking for is winsteps.com, home of the educational WINSTEPS & Facets Rasch Software.
Don't feel bad for the mistake though, it happens quite frequently and it's not your fault: whomever is behind winsteps.com does not make it easy to communicate with them.
If I had to take a guess, I would say that the decision NOT to have a clear contact email address on their website has already cost them plenty of lost business opportunities. Feel free to tell them I said so if you do manage to contact them. Good luck! :)
PostPosted: Tue Nov 01, 2016 5:56 pm
My sincere apologies and many thanks for the response!
Users browsing this forum: ppetroff60 and 249 guests
