 Post subject: Goofy Icon Blink
PostPosted: Fri Dec 15, 2006 2:10 pm
Whatever my first item is in the taskbar, the icon will blink off and on. Does anybody know why? Thanks.
PostPosted: Fri Dec 15, 2006 3:20 pm
I've seen this happen before too when the application is too busy to tell NextSTART what icon to use for the taskbar, but I don't recall this being tied to it being the first item on the taskbar or not... Are you sure it's always the first item, Gregory?
PostPosted: Fri Dec 15, 2006 3:24 pm
No, I guess I can't swear it's always the first item but it's the only one that does it. If that makes any sense.
PostPosted: Fri Dec 15, 2006 3:26 pm
Try to check which application is usually doing this and let me know please... See if we can find a patern or a reason why. :D
PostPosted: Fri Dec 15, 2006 3:38 pm
It's called "DFX" and is found at www.fxsound.com. Maybe it is just this application.
Users browsing this forum: Amazon [Bot], IvarR and 222 guests
