 Post subject: Resize pop-up window
PostPosted: Sun Jan 22, 2017 2:58 pm
Good evening everyone.
After using for years ObjectDock and RocketDock (lately in continually crash) I decided to install the Nexus Ultimate v.16.12, with which I am familiarizing since a few days.
I like it a lot but, in my opinion, it needs an option.
When you click on an icon in the dock, a pop-up window opens with the contents of the folder that I would like to zoom in as I require.
I attach a screen shot where you can see what I mean.
Without glasses I could not see the name of the program, nor will the icons.
Is it possible to change the appearance of this pop-up window?
Thank you.
(sorry for my english, i am an italian user)
 Post subject: Re: Resize pop-up window
PostPosted: Sun Jan 22, 2017 7:37 pm
Before we go any further, please read this product comparison page HERE so you know the difference between Winstep products. It's important so you can fully understand what I am about to explain below.
So now that you read that, let's clear a few things first: :)
1. You're not running Nexus Ultimate, you're running (or should be, since there is no trial version of Nexus Ultimate) the free version of Nexus.
2. That's not a pop-up window - that's an actual bona-fide menu. :)
Under the free version of Nexus and Nexus Ultimate, you cannot change the menus. So there is no way to alter their size, other than increasing the DPI of Windows (i.e.; high-DPI).
Under Winstep Xtreme, however, the context menus are provided by the NextSTART component, so they can assume the look (and size) of the currently loaded theme. Winstep Xtreme themes include skins for menus.
So, the answer is yes but only if you upgrade to Winstep Xtreme.
PostPosted: Sun Jan 22, 2017 7:45 pm
Isnt there an option to increase the font size? If purple has problem reading the menu that should help?
PostPosted: Sun Jan 22, 2017 8:01 pm
Unfortunately, not currently. Although that is actually a good idea to implement.
Users browsing this forum: No registered users and 160 guests
