 Post subject: Problem with "Empty Recycle Bin" sound in Nexus Ultimate
PostPosted: Fri Jun 16, 2017 11:55 am
Jorge,
Ever since Tuesday's batch of updates from Microsoft, I've had a problem with the sound associated with emptying the trash. This is reminiscent of a problem I reported almost six years ago. When I empty the trash, the sound gets clipped to just the opening portion of the sound, then it stops. It doesn't always happen, but often enough to bear reporting. I tried using a different sound but got the same results. Has anyone else noticed this?
I'm currently running:
•Windows 10 Pro Creator's Update with all of the latest patches installed
•Nexus Ultimate 17.01.1064
Windows 10 Pro[x64]
Nexus Ultimate 20.10.1154
Antivirus: Windows Defender
 Post subject: Re: Problem with "Empty Recycle Bin" sound in Nexus Ultimate
PostPosted: Fri Jun 16, 2017 8:29 pm
What else is there to say? ;)
Only suggestion I could think of was to try a different sound file, but you already did that.
PostPosted: Fri Jun 16, 2017 9:19 pm
Jorge,
I was hoping you might have heard of someone else having a similar problem and might plan on doing something about it (assuming you are testing/compiling on the same version of Windows).
I did run the following which came up clean:
• sfc /scannow
• Dism /Online /Cleanup-Image /RestoreHealth
As usual, I'm the only person with my problem.
Thanks,
Grouch
Windows 10 Pro[x64]
PostPosted: Wed Aug 23, 2017 6:44 am
Grouch wrote:
Jorge,
I was hoping you might have heard of people on phenq having great results and someone else having a similar problem and might plan on doing something about it (assuming you are testing/compiling on the same version of Windows).
• sfc /scannow
Thanks,
Grouch
Hey Grouch, same problem here. Did you find a fix?
Last edited by Brandstetter on Wed Oct 30, 2024 11:07 am, edited 8 times in total.
PostPosted: Wed Aug 23, 2017 7:29 am
@Brandstetter,
Indirectly, Yes. I had another problem of accidentally deleting a dock item when I meant to rename it. Jorge directed me to the following: Preferences/General/More Options/Recycler Settings/Display Confirmation Dialog Before Deleting. Voila! Killed two birds with one stone.
Hope that works for you,
Grouch
Windows 10 Pro[x64]
PostPosted: Wed Aug 23, 2017 8:49 am
By the way, one thing you guys should understand: the Winstep application *itself* is not responsible for the action of playing a sound.
Basically all it does is say to Windows: here is the location of a sound file, please play it. It then turns its back and assumes Windows will perform the required task.
So, if there are any issues at this stage, they will be on the realm of Windows, sound drivers, decoders, filters, etc... All things external to the Winstep application itself.
PostPosted: Wed Aug 23, 2017 10:20 am
Unless, if after telling it to play the sound, it tells it to do something else which overrides the playing of the sound :wink: . In any case, I try not to argue with success.
Windows 10 Pro[x64]
Users browsing this forum: Amazon [Bot], Apple [Bot], Bing [Bot], Google [Bot] and 87 guests
