 Post subject: How to create a subdock from existing dock
PostPosted: Sat Nov 25, 2017 8:25 am
I have not been able to find this, nor figure it out.
I ave a number of docks. I use them to easily find groups of documents. As time goes on, those groups are used less frequent. So I want to "move" these dock into a shelf (not creating a shelf from the dock, just placing the dock in a shelf, or in a dock already in the shelf).
I cannot figure out how to get my dock become a sub-dock of an existing dock, or to get it into one of the empty slots in a shelf, both should work if I could do it.
What is the way to achieve it?
--- Mats ---
 Post subject: Re: How to create a subdock from existing dock
PostPosted: Sat Nov 25, 2017 11:21 am
--- Mats ---
Yo need to enable dock control icon in dock properties then use that icon to attach the dock as subdock (if i remember right)
PostPosted: Sat Nov 25, 2017 12:13 pm
Thank you.
It is already enabled in both the dock to be included as well as in the one to be included in. I can though not drag it in, and I can not find it as a file to drag into the dock either. Do you know where to find the dock so it can be referenced? Or that is not the way to do it?
PostPosted: Sat Nov 25, 2017 1:02 pm
you need to grab the icon itself (icons need to be unlocked) not the dock:
http://prntscr.com/hf2c4d
then you insert the icon where you want the dock to be subdock:
http://prntscr.com/hf2ci0
and now you have moved the dock to be a subdock of another dock (or shelf):
http://prntscr.com/hf2cs0
(for this i duplicated my dock to the left, then inserted the duplicate as the subdock of the original)
PostPosted: Sun Nov 26, 2017 3:59 pm
Thank you. Managed to unlock Icons. But that was the end of the success.
My dock consist of a number of items, all with icons. I tried to drag not one of the items, but all of the items at once. Thus dragging the "dock". I can drag it, but it "moves" rather than "drags" so it never lands in the dock where I want it to become sub-dock (no way to place it in the dock, it just places it at the same place as the dock).
--- Mats ---
PostPosted: Mon Nov 27, 2017 2:47 am
Ok, first make sure that the control icon (the Nexus icon as the very first icon in any dock) is on for the dock: Dock Properties -> Content tab -> enable 'Show dock control icon' setting.
The very first icon in that dock will now be a Nexus icon. It is this 'control' icon that you drag into another dock, as if you were drag & dropping an item from one dock into another.
PostPosted: Tue Nov 28, 2017 8:56 pm
to illustrate:
no dock control icon:
http://prntscr.com/hgihzq
http://prntscr.com/hgiizq
dock control icon enabled:
http://prntscr.com/hgijhu
you grab just the control icon, but it takes the whole dock with it when you drop it:
http://prntscr.com/hgikny
http://prntscr.com/hgim61
http://prntscr.com/hgimmk
PostPosted: Tue Nov 28, 2017 9:18 pm
Also, make sure icons are not locked for the dock.
Users browsing this forum: Amazon [Bot] and 196 guests
