Board index : Winstep Forums : General Discussion  [ 73 posts ] Go to page Previous  1, 2, 3, 4, 5
 Post subject: Re: E-Mail Checker using SSL
PostPosted: Sun Dec 10, 2017 11:33 pm
Randy, there's a new beta out which should have fixed the issue with AT&T. Can you please test it to make sure and let me know? :D
I will be happy to test it but I need for you to tell me how to get the beta build.
PostPosted: Mon Dec 11, 2017 1:28 am
Preferences -> Advanced tab -> Enable 'Notify me of beta (test) versions' -> Check for Updates
PostPosted: Wed Dec 13, 2017 5:47 pm
So, any news on this? :P
PostPosted: Thu Dec 14, 2017 12:03 am
I've been out of town but will try the beta this weekend and report the result.
Randy
PostPosted: Sun Dec 17, 2017 2:56 pm
Hmmm... Only partial success.
I downloaded the Nexus Ultimate beta 17.12.1066. The Mail Checker now appears to connect without error to the AT&T mail server. The "OK Password required." message no longer shows and the Last Checked message shows the date/time correctly. The Response, however, always shows 0 Messages, 0 Bytes, whether there are messages or not.
Randy
PostPosted: Mon Dec 18, 2017 4:03 am
Randy, are you sure the messages were not already downloaded into your email client?
You do understand how the email checker module works for POP3 accounts, right?
PostPosted: Mon Dec 18, 2017 4:19 pm
Hi Jorge,
Yes, I'm quite certain.
Here is sequence-
1) send email message to AT&T account
2) close email client (Outlook)
3) wait for mail to arrive at POP3 server
3) check for mail with Mail Checker (0 messages)
4) open Outlook
5) download message sent earlier
Randy
PostPosted: Wed Dec 20, 2017 5:45 pm
Jorge,
I can set you up with an account so that you can access that server directly, if that would be of help.
Randy
PostPosted: Wed Dec 20, 2017 8:06 pm
Randy611 wrote:
Jorge,
Randy
Yes, please! :)
PostPosted: Thu Dec 21, 2017 10:07 am
Thanks! And, just like that, the issue has been identified and fixed.
Turns out what was happening was nothing like I thought initially: usually you get a server response like '+OK' followed by a space and some data (if something goes wrong the server will respond with a '-' instead of '+' sign).
AT&T was simply sending the '+' first and the 'OK' after (i.e.; in two separate packets). No idea why, but, then again, I'm not a specialist in email protocols.
Since the Email Checker only cared about the '+' sign, it was basically sending the password before the server on the other side was ready to receive it.
Now I simply wait for the rest of the data to arrive before sending the password and it works like a charm.
Thanks for your help! :)
PostPosted: Tue Jan 02, 2018 2:48 am
I updated to the latest beta. The Mail Checker works perfectly.
Thanks!
Randy
PostPosted: Tue Jan 02, 2018 1:30 pm
You mean the official v17.12 release. :wink:
Thanks for letting me know. :)
PostPosted: Tue Jan 02, 2018 1:48 pm
Oops... I have 17.12.1069. I had checked the "Notify for beta versions" earlier and, when it found a newer version the other day, assumed it was another beta.
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 73 posts ] Go to page Previous  1, 2, 3, 4, 5
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot], GPT [Bot] and 135 guests
